BMWx5
Want retro fit Sat Nav on 03 x5
Hi everyone
I'm new to this. i have got a 03 NZ new X5. and looking at getting a Nav retro fit . the car have 16:9 monitor head unit, play TV, have 6 disk CD changer at the back..
what else do i need other then " Sat Nav dvd drive that goes into the boot & the antenna that goes into the tailgate" do i also need a new loom as well to run?
how much would that estimate cost... ( labour & parts )
As much help as possible would be great.
One last thing. is anyone live in Wgton know any good garage other then Jeff Grey. Plus know how to retro fit that the Sat Nav .. :)
thanks
terry
terry
PM member 'Jochen.' He is the absolute master with all BMW electronics.
Also Josh, 'Hybrid,' might be able to help, he's retrofitted nav (16:9) into his e46 (Might be same deal, don't know).
Hi everyone
You have one of the easiest cars to retrofit. It's really simple.
You bolt in a bracket, plug in a small loom in the boot, fit the antenna and slide in the nav. Done.
All the work happens in the boot.
Very easily DIY.
You must use a Mk4 nav (Mk3 cannot be used in the X3).
Mk4 nav new is about $5,000, or 2nd hand around $700 to $1200 depending on your luck
2nd hand see ebay, or email hotwire on this forum, he probably has a nav available.
Bracket from BMW new, plus about 2 or 3 bolts. See RealOEM for part numbers.
And at the end get BMW to run the retrofit coding so you car has nav properly entered in its options list
