FKat 0 Report post Posted April 23, 2009 Hey does anyone know where the thermostat on a 1991 E36 engine is? Is it the bit where the top radiator hose goes into the engine? Churr. Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted April 23, 2009 FKat said: Hey does anyone know where the thermostat on a 1991 E36 engine is? Is it the bit where the top radiator hose goes into the engine? Churr. 91 non-vanos has an alloy thermostat housing [ which both hoses are attached to ] It's behind there. don't just pull the thermostat because of overheating ,E36's have a bad reputation for shitting the waterpump and also some morons out there [gas station pump jockeys] don't know about bleeding the air from the cooling system Quote Share this post Link to post Share on other sites
FKat 0 Report post Posted April 23, 2009 kerrynzl said: 91 non-vanos has an alloy thermostat housing [ which both hoses are attached to ] It's behind there. don't just pull the thermostat because of overheating ,E36's have a bad reputation for shitting the waterpump and also some morons out there [gas station pump jockeys] don't know about bleeding the air from the cooling system Oh ok, is that whole section the thermostat then? Because there seem to be two separate parts each of the hoses go in to, which are part of one bigger part. Quote Share this post Link to post Share on other sites
