detbeamer
Fuel Pump (320i)
Hello iv put a sr20det in my e30 coupe just want to find out what the hp rateing of the 320is feul pump is think ill have to by a new one but im hopeing it mite work just want to find out bfor puting $350 in to an aftermarket one
thanks
Bruce.
Bruce, Firstly, punctuation would make your post a hell of a lot easier to read & interpret:-
Fuel pressure - from memory - runs at about 33-34psi @ 2.5 -3 litres per min delivery
Guest FrantiC
325i, 320i would use the same fuel pump AFAIK. Which would run 3bar on a 325i, or 2.5bar on a 320i (depending on FPR). You can easily get a 500hpwalbro external and hook that up, $180 or so on trademe just avoid the shity replicas which use plastic gears in the motor..
thanks a lot guys :) yea iv look ont trademe and dont wana get one off there, there cheap coz there sh*t lol
the e30s one will be ok for a start mostly get a genuine bosch 350hp from jap raceing here in chch
anyway thanks again for ur help :)
