Forrest 35 Report post Posted May 4, 2009 Have searched about 6 forums trying to find a step by step DIY of this. Have found bits and pieces, but no straight step by step in one place, I am sure somebody has a treasure trove of info somewhere on them, am finding this very frustrating. Didn't help that the US didn't get the m40 Just a link/thread with some pics etc would be helpful if anyone has seen one. Any help is appreciated. Nathan Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 5, 2009 Hey Gus did one not long ago, m40b16 swapped with an m42. Should talk to him. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted May 7, 2009 Bump for attention: GUS and anyone else who can help....do want to do this..... Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted May 7, 2009 Attention: JiB.... 1. Its possible but you need some bits from a e30 m42 to make it go in - you'll need the e30 engine loom (unless your good with wiring, in which case could probably use the e36 loom and get around the security), e30 exhaust manifold and I think I heard something about a PAS pump but I'm not sure. 2. We did it on ours couple of years back. You need an E30 oil sump, go for the E30 manifold as it gives slightly better torque, The loom is very similar IIRC but don't quote me, the mounts need changing too IIRC. Quote Share this post Link to post Share on other sites
