supes
e30 Mags
Hi Guys,
I have finally acquired a set of alloys for my 320i. The offset and stud pattern suit however the mags don't sit properly on the hub i.e. the hole of the mags is too big so basically just the bolts are holding the wheels together.
Has anyone come across this before? what's the fix :banghead:
Cheers!
I was told they were the perfect fit. Not too sure what to expect.
Are the hubcentric rings legal :wub:
Can anyone recommend a good tyre/mag place to go to sort this out properly?
I want the grief to be over!
Guest Spargo
Yes they're legal.
Magwarehouse / Mag and Turbo / Top Town / any mag wheel place really.
Just to confirm, the centrebore of the mag is larger than the hub?
That's right, The centrebore of the mag is larger than the hub and so it doesn't sit on it instead the mags are being supported by the bolts only
what sorta mags are they? ive got my old ones from advantis that you might be able to use
i heard rings, spacers etc are now illegal
Rimrite down here in Palmerston North can modify the wheels tho, if u wanna do it that way, apparently a real good place
you dont park ya car on constellation drive do you? near wendys....sacked out as on the back? gimme a msg on here and can meet up or something
