DRTDVL 0 Report post Posted May 19, 2009 I originally got this for the racecar but it was too big, used for all over about 4 hours total. It's a sealed battery so can be mounted in any orientation. The battery terminalls are square with a hole drilled through (see photo) to bolt the pos and neg wires to using a nut and bolt. Length 197 Width 165 Height overall 170 RRP: $400 Looking for around $200 http://www.yuasabatteries.com/pdfs/NP_38_12_DataSheet.pdf <--- Data Sheet Quote Share this post Link to post Share on other sites
