tibbs.james 1 Report post Posted May 30, 2009 Hi Guys I have noticed these BBS wheels on Trademe & i would like to get them for my 300zx. they are cheap & i like them and a good size at 16x7 for my Nissan (1985 Z31 ) if these could be re drilled then i could get away with longer studs and a 10mm spacer rather than a full on cert required 5x120 to 5x114 spacer giving me a crazy low offset. I would like to know if these wheels have enough meat on them to be re drilled Searching Google only came up with references to re drilling RS variant wheels. Can anybody ID the exact model these wheels are ? Does anybody have pictures of the rear of the hub for these type of wheels ? http://www.trademe.co.nz/Trade-Me-Motors/C...n-220532567.htm Any thoughts appreciated. Cheers James Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted May 30, 2009 there should be enough meat in them, my dad has had race car wheels re-drilled many a time with no troubles. Also, cant find website at the mo but there is a crown which has some tricky wheel studs which can change the stud pattern so long as its 5stud to 5 stud or 4 stud to four stud. Will look for their business card today. BTW thanks for your help yesterday mate its much appreciated. Would like to come see you Nissan sounds awesome from what you have said Cheers Sam Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted May 31, 2009 Thanks for the wheel info Sam. They are so cheap on TM i might just take a punt it sounds worth it for the tires anyway. Yeah the old Nissan 300zx is a fairly interesting, I need to get onto building my Equal Length headers for it, been so lazy with this cold weather at the moment. anybody else know what exact BBS wheels these are ? Quote Share this post Link to post Share on other sites
