tibbs.james
Getrag 260 M20
Hi all
If Ray can Sort a Box for me that means my Other E30 Getrag 260 is for sale
Its always had good Fluid in it, however it suffers the Getrag rattle.
It shifts into every gear fine and doesn't crunch unless its really cold in winter.
(-2 deg frosty morning cold)
Shifting is vague& a bit notchy, i believe this is more than the usual shifter bushings.
Gearbox on its own, no shifter linkage with it or mounts or anything.
I don't know that they are easy to disassemble so I'm not real keen about splitting it up.
$220 ono can be test driven in car.
Or Make an offer..... if you have a use for it ?
Taking up space it needs to be gone
Box is in Christchurch, can be sent around NZ to a Main Freight Depot at your own cost.
Edited by Jimmy
Hey could be keen, priced a bit rich for a suspect box.is it facelift g/box or pre f/lift. your right about not wanting to strip the box its a extreemly fun job without correct tools.
Feel Free to Argue with me on the price, ONO applies here.
It is a face lift box and does not have the bell housing sensor holes.
Down to $150, as mentioned to Brent in another forum.
Cheers
James
