AzonicNick
Windscreen seal?
Hey all,
Just spotted this while cleaning my car this morning, looks like the seal around the windscreen has come loose. Seeing as the car sees a fair bit of rain being parked outside a lot Im wondering if its something I should get looked at ASAP.
Below is a pic, it's flexible, ie I can push it down to where I think it should be sitting. I just dont want water running down into some place it shouldnt be..
any ideas?
Looks like it is just the cowl to me. but i would get it sorted as i would not like to guarentee no leaks
Yea im keen to get it sorted ASAP if its going to cause a problem.
Has anybody had a similar issue? I cant figure out where the water goes. And looking on realoem its the splash wall, and there is no real way to replace this and it looks expensive. There must be a fix though?
no1..
Posted Image
Can you just press the white plastic clips back in again so it seals back up?
I had a quick go while it was raining, I think they are a bit past it though. Will have another play.
Why does this happen in winter lol :rolleyes:
