tire 10 Report post Posted June 27, 2009 Anyone done it before? They screw in all good but the connections are different, so if i just wire up the right connections is there any reason why it wont work? ta Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted June 27, 2009 (edited) Anyone done it before? They screw in all good but the connections are different, so if i just wire up the right connections is there any reason why it wont work? ta Done it on mine (not smileys, but facelift lights) - just wire up to the right wires (park to park, dipped to dipped etc - only thing that doesn't work is the headlight height adjusters, unless you were to wire them up to a switch maybe? Edited June 27, 2009 by bmpower Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 27, 2009 Done it on mine (not smileys, but facelift lights) - just wire up to the right wires (park to park, dipped to dipped etc - only thing that doesn't work is the headlight height adjusters, unless you were to wire them up to a switch maybe? Slightly off topic,,, But does the Headlight Height Adjuster have a tendancy to break? I'm unsure if mine works.. doesn't make a difference no matter what I've set it to. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted June 27, 2009 ^ Mine broke...most facelifts by now are old and the die pretty easily Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 29, 2009 Yayz it works! Quote Share this post Link to post Share on other sites
