pureboiracer
guage options
hey guys.
i need to get some guages, tacho, fuel that will work in e30 tank, speedo, bat +, oil pressure coolant temp.
need aftermarket guages and want relitavly good quality ones.
what brand should i be looking for?
Please dont suggest factory e30 stuff as that is what i am moving away from.
hopefully a speedo that will work with e30 factory pickup.
Cheers for any help.
oli
Edited by sydwayz e30
Good Auto Meter ones...
I like the ones that you can only see when they're powered up.
But...
What's wrong with the factory Speedo and Tach?
Fair enough for additional oil/batt/water ect.... if it's pushed hard all the time...
if the tacho is anything like the 205's one, it reacts way way way to slow...
i've hit the rev limiter at what looks like 5,900 rpm instead of 7200 rpm
I bought VDO gauges from eGauges.com - not too bad for price including shipping.
Fuel level might be hard, and speedo costs $$$, so you kinda have to really want it. EG:
Kit with most stuff:
http://www.egauges.com/vdo_mult.asp?Type=I...p;Series=Vision
Plus tach:
http://www.egauges.com/vdo_mult.asp?Type=T...ion&Units=E
I'm not sure of cheaper options.
Omori.
Clean looking, wicked quality, easy to read on the track and in tough lighting conditions.
If your dead set on a getting a speedo get one from Stack. Please.
You will rule the world if you do.
http://www.stackltd.com/tacho1.html
