SIR E30
WTB/Swap
Hey there, Does anyone have any 20mm 4x100 to 4x100 hub adaptors?
Keen to buy or swap for my 25mm 4x100 to 4x100 adaptors.
Cheers, Jase
Just get your spacer machined down 5mm?
The end of the stud that is in the spacer sits flush with the back of the spacer, dont think its gonna work like that. Itd be easier to swap them over with someone who wants a lower offset :P
yeah wouldnt you be able to just machine it? as in machine the side the studs come through on just press the studs out to do it. it will give you a 5mm option for a locator lip aswel to fit the new mags so you dont get the spacer jitters at 100kms
^^what he said, had Brugar engineering do exactly that a while ago.
I think what they mean is Jase, is to press the studs out and lathe them down from the wheel side of the spacer not the hub side. Also depends on how long the knurl is on the studs your using too. If it comes a fair way through the thickness of the spacer it wont leave much left to hold the stud in once machined down..
All valid points people! I think that will be the plan..
Ive decided to wait till I get the new wheels and try and fit them to see if I can get away with it, if not THEN Ill get them machined, Ive got a mate who is amazing on a lathe so itll be no biggie..
