kurtyb 1 Report post Posted July 10, 2009 there is a light that flashes on and off at random times while driving? ? and im wondering if i should be worried? its a circle with 3 squares on the left and right of it? what is it? and why is it comming on! ahaha iv had my e30 for a week so forgive my noobieness! Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted July 10, 2009 there is a light that flashes on and off at random times while driving? ? and im wondering if i should be worried? its a circle with 3 squares on the left and right of it? what is it? and why is it comming on! ahaha iv had my e30 for a week so forgive my noobieness! Brake pad sensor, Means your brake pads are starting to go. Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted July 10, 2009 Thats your brakepad sensor mate, tells you when they need replacing, but it could be as simple as corroded points on the plug , theres a wire that goes to the front passenger brake caliper and one to the rear drivers side wheel, and about 100mm from the caliper there is a plug, puull that apart and put a but of crc in ther and clean it up and see if that makes a difference, and if you can , have a look at the pads at the same time Quote Share this post Link to post Share on other sites
kurtyb 1 Report post Posted July 10, 2009 oooooooooooooooohhh ahahah now i feel preti blond! ahahaha! thanks!!!!! Quote Share this post Link to post Share on other sites
