Old_Skool_Bmw 0 Report post Posted July 20, 2009 have put a full set of Toyto R888's on my M3 but i'm having a few problems with the front's rubbing on full lock. the very edge of the tyres is catching the inner guard so it seems the tyres are too wide compared to the stock rims it used to have. Rims are 17x8.5 and I'm running 235/40/17 all way round. stock rim size 205/55/15 on 7"s I'm contemplating changing from 235/40/17 to a 215/45/17 to reduce the 'width' and 'height' of the sidewall & overall size of the tyre.. Just curious to know if there will be any major problems running 235/40/17 on the rear and 215/45/17 on the front with all rims the same size. Laurence Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted July 20, 2009 il swap ya for my 17s with toyos on them. 235 on rear + 215 on front = understeer. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted July 20, 2009 Understeer on stock suspension and sway bars anyway.. Would be good with some uprated stuff. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted July 20, 2009 Old_Skool_Bmw said: have put a full set of Toyto R888's on my M3 but i'm having a few problems with the front's rubbing on full lock. the very edge of the tyres is catching the inner guard so it seems the tyres are too wide compared to the stock rims it used to have. Rims are 17x8.5 and I'm running 235/40/17 all way round. stock rim size 205/55/15 on 7"s I'm contemplating changing from 235/40/17 to a 215/45/17 to reduce the 'width' and 'height' of the sidewall & overall size of the tyre.. Just curious to know if there will be any major problems running 235/40/17 on the rear and 215/45/17 on the front with all rims the same size. Laurence Get some rack-stops made up (or from TurnerMotorsport). Custom ones are good, as they may not need to be as thick as the ones you can buy. I personally wouldn't go for a staggered tyre setup. Quote Share this post Link to post Share on other sites
