Boost Junky
FS: M50 Exhaust Manifolds for E30 Conversion + AFM
As pictured below I have a set of M50B25 Exhaust manifolds to suit E30 M50 conversion, these were modified to clear the steering arm on my E30. Just needs two studs on the rear ones and they are good to go. I also have pictured a perfect working M50B25 Air flow meter
Manifolds $80ono
AFM $ 60ono
Make an offer guys ;)
Posted Image
Posted Image
Posted Image
[edit] forgot pictures
Edited by Boost Junky
The outlet flanges sit on different angles, is it easy to remove the exhaust with them like that? Or is that why the studs are cut shorter on one of them?
You said make an offer so here goes!
Manifold for sucky sucky..?
