Hartage
e30 325i 1990
As topis title says, My NZ new 325i is running a bit rough, Normally a smooth running car has developed at between 2k and 3k revs in any gear what starts as a flat spot in acceleration and is now like an intermitant on off power. ( if that makes any sence )
Tried most basic things like the plugs, fuel filter, fuel pump etc cant seem to make iot better, and is slowly getting worse.
Wondered about TPS, as its worse if you maintain an even throttle.
Any ideas??
^ Clean Airflow meter and Throttle Body?
Done this, several times, no real improvment.
Sounds like from my totally unexperienced opinion that it is the TPS if it is in every gear.
Oh and you have a PM
Edited by Forrest
