DFF53 1 Report post Posted August 25, 2009 (edited) Well i would like to see it go to a good home. so $2500 with extra parts listed below or $2000 without. Surely some one wants a e32. Not much left to be perfect , needs new brake pads and rotors, and front upper control arms and rear pitman arms. All can be sourced from B.S. members. for not much. Very nice drivers car , but it is hardly used now since i started University. This car has documents since brand new. Current wof and rego. Atlantis Blue with Silver Grey leather, around 238000ks. All mechanical work done only by : BMW Japan Service European Vantage Engineering and Marque Automotive Things changed within the last two years (which you don't have to worry about): New engine mounts New gearbox mounts New water pump New front lower control arms New Heater valve New V-Belts Gearbox serviced, ATF and filter. Issues (If you can call them that) Dents and scratches par with the cars age Headling sagging Instrument cluster light not working. Front tyres need replacing and wheel allignment. Extra parts Original set of original Trx wheels with low tread. Sony cd player with frontal aux and usb port (car has factory 10 speaker Sony system) Spare Head for the engine. Spare inlet manifold Electric rear seat off a 750il (Will need to be wired) 50mm lowering springs as in first picture below . Spare middle muffler section non cat version. ( all you have to do is install and connect the o2 sensor to it) Free flow rear muffler by previous owner. Unfortunately the Schnitzer wheels in the pics were sold another B.S. member last year. http://www.bimmersport.co.nz/forums/index....st&id=21735 http://www.bimmersport.co.nz/forums/index....st&id=15987 More pictures below. http://www.cardomain.com/ride/2649294 Would like $3500, $2500 with extra parts listed above or $2000 without, text 021 062 1685 Edited September 27, 2009 by 735IL Quote Share this post Link to post Share on other sites
DFF53 1 Report post Posted August 29, 2009 Come on guys , put in your best offer , can also sell it for less without the trx's , head , inlet maifold, electric rear seats and middle exhaust section. Quote Share this post Link to post Share on other sites
DFF53 1 Report post Posted September 27, 2009 Well look at the price reduction above. My loss your gain. Quote Share this post Link to post Share on other sites
