lbirgel 0 Report post Posted August 30, 2009 Hey guys Just a question. Around 2 weeks ago I noticed that when I’m driving around 100km/h I start to feel a vibration coming from the rear of the car. It has just started to happen. I was wondering if this could be the wheel bearings. I had the front bearings replaced a year ago and it was the same sort of symptoms. What do you guys think? Cheers Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted August 30, 2009 Can be alot of things, Worn subframe bushes, trail arm bushes, diff mount or yeah wheel bearings. Don't wheel bearings usually make a rumbling sound when they are busted though? Or if you jak the car up the wheel will jiggle a little if you try to shake it around. Quote Share this post Link to post Share on other sites
lbirgel 0 Report post Posted August 30, 2009 yeah with my fronts the vibration got worse and started to make a rumbling sound. will take it to the mechanic to get checked out. cheers Quote Share this post Link to post Share on other sites
