greenday-rulz21 5 Report post Posted September 5, 2009 I have a set of interior bulbs which I don't want anymore. The set I have replaces all the interior lights which fade/turn on and fade/turn off when you unlock/lock the vehicle. The set is only good for E36's afaik. Might work on other models but not my responcibility to find out. Includes: 2 x 36mm LED Festoon bulbs - (Used in the footwells) 3 x 42mm LED Festoon bulbs - (Used in main dome light, In boot, and one spare. (Could find a place that uses it, maybe glovebox?)) 2 x Bayonet LED bulbs - (Used in the two rear pillar lights) I purchased these previously in mostly individual pairs. Each of the 42mm bulbs cost me $15+, 36mm's approximately $12, and the bayonets about $7 each. Approx. $85. I am wanting $60 for the lot. Or $52 for the lot but only 2 42mm's. If you purchase the lot I will throw in a pair of 12V 55W White headlight bulbs. And also a pair of cheapish LED park light bulbs. Pm or post here if you're keen. Quote Share this post Link to post Share on other sites
greenday-rulz21 5 Report post Posted September 5, 2009 Btw, all of the interior bulbs are White LED bulbs. Meaning they put out a white light instead of that dated yellow light. It is a great improvement over the standard dated yellow look. Quote Share this post Link to post Share on other sites
misgvous_1 0 Report post Posted September 5, 2009 I'm keen to take these Cheers Jamie Quote Share this post Link to post Share on other sites
