greenday-rulz21
F/S: White LED Interior + Headlight Bulbs
I have a set of interior bulbs which I don't want anymore.
The set I have replaces all the interior lights which fade/turn on and fade/turn off when you unlock/lock the vehicle.
The set is only good for E36's afaik. Might work on other models but not my responcibility to find out.
Includes:
2 x 36mm LED Festoon bulbs - (Used in the footwells)
3 x 42mm LED Festoon bulbs - (Used in main dome light, In boot, and one spare. (Could find a place that uses it, maybe glovebox?))
2 x Bayonet LED bulbs - (Used in the two rear pillar lights)
I purchased these previously in mostly individual pairs. Each of the 42mm bulbs cost me $15+, 36mm's approximately $12, and the bayonets about $7 each. Approx. $85.
I am wanting $60 for the lot. Or $52 for the lot but only 2 42mm's.
If you purchase the lot I will throw in a pair of 12V 55W White headlight bulbs. And also a pair of cheapish LED park light bulbs.
Pm or post here if you're keen.
Btw, all of the interior bulbs are White LED bulbs. Meaning they put out a white light instead of that dated yellow light. It is a great improvement over the standard dated yellow look.
