Gunner 0 Report post Posted September 8, 2009 (edited) the light which indicates which mode i am in doens't like up anymore? so at nite i can't see what i am in. even harder now cause the letters don't light up. checked basic fews bt unsure cars a bmw e36 320i Edited September 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted September 8, 2009 the light which indicates which mode i am in doens't like up anymore? so at nite i can't see what i am in. even harder now cause the letters don't light up. checked basic fews bt unsure cars a bmw e36 320i Check the light bulb Check the contacts are clean and shiny and tight What transmission do you have? EGS A4S 310R, (with A M switch = Auto, Manual) or EGS A5S 310Z (with E*S switch = Economy, Ice, Sport) The illumination of the A/M or E*S switch is caused by bulbs inside the switch and fed from a separate power source to the transmission control, but I think this is not your problem. I think you mean the transmission position indicator light is not working. The transmission position indicator light is fed from the light switch via the dimmer At the transmission position indicator light: Green/red wire is power for illumination Ground will be a brown wire. The green/red wire comes from the illumination dimmer switch, which also feeds all other interior illumination If all other illumination works (ashtrays, hazard light, ASC switch, instrument cluster illumination), and just the transmission position indicator doesn't, then check the wire feeding the lamp, check the lamp connections, check the earth wire, etc. Should be easy to find. Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted September 8, 2009 Check the light bulb Check the contacts are clean and shiny and tight What transmission do you have? EGS A4S 310R, (with A M switch = Auto, Manual) or EGS A5S 310Z (with E*S switch = Economy, Ice, Sport) The illumination of the A/M or E*S switch is caused by bulbs inside the switch and fed from a separate power source to the transmission control, but I think this is not your problem. I think you mean the transmission position indicator light is not working. The transmission position indicator light is fed from the light switch via the dimmer At the transmission position indicator light: Green/red wire is power for illumination Ground will be a brown wire. The green/red wire comes from the illumination dimmer switch, which also feeds all other interior illumination If all other illumination works (ashtrays, hazard light, ASC switch, instrument cluster illumination), and just the transmission position indicator doesn't, then check the wire feeding the lamp, check the lamp connections, check the earth wire, etc. Should be easy to find. Thanks for that will do. and is it normal for the letters not to light up? so only the transmission indicator to light up? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted September 8, 2009 Thanks for that will do. and is it normal for the letters not to light up? so only the transmission indicator to light up? Sounds right, long time since I saw one in the flesh, and at night :-) Quote Share this post Link to post Share on other sites
