Jezza 0 Report post Posted September 9, 2009 (edited) Hey guys Been hunting around for some calipers from a 735i, after reading a post on here and some other info off google. From what I have read I need the 'carriers'/brackets as well. I managed to find a set but the person selling them says the brackets are part of the strut assembly Do I need the e32 brackets or will the calipers bolt straight onto the existing e28 brackets? If I do need the e32 brackets how do I go about changing them? He told me they were "sealed". Thanks for any help EDIT: I've been told these calipers just literally bolt on with the correct rotors. Thanks anyhow. Edited September 9, 2009 by Junkers Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted September 10, 2009 Hey guys Been hunting around for some calipers from a 735i, after reading a post on here and some other info off google. From what I have read I need the 'carriers'/brackets as well. I managed to find a set but the person selling them says the brackets are part of the strut assembly Do I need the e32 brackets or will the calipers bolt straight onto the existing e28 brackets? If I do need the e32 brackets how do I go about changing them? He told me they were "sealed". Thanks for any help EDIT: I've been told these calipers just literally bolt on with the correct rotors. Thanks anyhow. Sounds to me like the person selling them is confused about what you want. I think you need the carriers as well (someone correct me if wrong) but these bolt onto the strut assembly by two bolts. The carrier is very easy to remove - use a 17mm socket and pull off. Normally you would get the carrier with the caliper Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted September 10, 2009 Sounds to me like the person selling them is confused about what you want. I think you need the carriers as well (someone correct me if wrong) but these bolt onto the strut assembly by two bolts. The carrier is very easy to remove - use a 17mm socket and pull off. Normally you would get the carrier with the caliper you are correct but if the carrier wont bolt to strut youll need to make a bracket, easy fix Quote Share this post Link to post Share on other sites
