Jezza
E28 Brake calipers to 735i calipers
Hey guys
Been hunting around for some calipers from a 735i, after reading a post on here and some other info off google. From what I have read I need the 'carriers'/brackets as well. I managed to find a set but the person selling them says the brackets are part of the strut assembly :wacko:
Do I need the e32 brackets or will the calipers bolt straight onto the existing e28 brackets? If I do need the e32 brackets how do I go about changing them? He told me they were "sealed".
Thanks for any help
EDIT: I've been told these calipers just literally bolt on with the correct rotors. Thanks anyhow.
Edited by Junkers
Hey guys
Thanks for any help
Sounds to me like the person selling them is confused about what you want.
I think you need the carriers as well (someone correct me if wrong) but these bolt onto the strut assembly by two bolts. The carrier is very easy to remove - use a 17mm socket and pull off. Normally you would get the carrier with the caliper
you are correct but if the carrier wont bolt to strut youll need to make a bracket, easy fix
