bmwsparkle
3.2 M3 block, pistons, and conrods
its without head, and i can take a guess a head to match would be next to impossible to find
so only good for someone with M3 already
Not at all, anyone with a M50/52 could use this bottom end, with a bit of porting & cam work a M50 head would be fine, similar theme to the Schintzer S3.
Or some one with a M20 wanting to build a beast 3.0l stroker could use the crank.
The add sounds odd though as a 3.0l & 3.2l use different cranks & rods!?!?!
glenn....is the crank a straight swap? or would machining be needed?
From what I have read they need the front mainseal or main bearing part of the crank enlarged to suit the M20 block, not a bolt in but can be fitted.
Have a search on the US forums, I think IE used S50 cranks in their 3.0l stroker kits!?!?!
