l0w320
installing new stereo
hey guys
i have just bought a new head deck for my bmw 89 e30
problem is when i bought the car it still had the stock tape player in it so ive pulled that out and it has that weird stock radio plug which i dont have the confidence to cut just yet until i know what the basic diagram is?
anyone here know
i know its a long shot but i thought i might as well ask see if anyone has any advice
thanks
garry
if you know that basic red (acc) yellow (constant) and black (ground) you should be sweet. most e30s have the correct colour codes and its just a matter of matching the wires
Edited by Wervie67
my one looks a bit more complicated than just matching the wires
anyone know where to find a wire diagram?
Guest FrantiC
e30 isn't colour coded. Pretty sure its the brown/purple wire that is the switched +!2V (acc) joins to red.
You can figure out the wires with a multimeter which is the constant +12v, which is the switched +12v, etc.
the two e30s ive worked on have been colour coded (both pfl if that makes a difference)
but your right, multimeter's do save alot of time. and for speakers, just use a battery.
