l0w320 0 Report post Posted October 26, 2009 hey guys i have just bought a new head deck for my bmw 89 e30 problem is when i bought the car it still had the stock tape player in it so ive pulled that out and it has that weird stock radio plug which i dont have the confidence to cut just yet until i know what the basic diagram is? anyone here know i know its a long shot but i thought i might as well ask see if anyone has any advice thanks garry Quote Share this post Link to post Share on other sites
Wervie67 0 Report post Posted October 26, 2009 (edited) if you know that basic red (acc) yellow (constant) and black (ground) you should be sweet. most e30s have the correct colour codes and its just a matter of matching the wires Edited October 26, 2009 by Wervie67 Quote Share this post Link to post Share on other sites
l0w320 0 Report post Posted October 26, 2009 if you know that basic red (acc) yellow (constant) and black (ground) you should be sweet. most e30s have the correct colour codes and its just a matter of matching the wires my one looks a bit more complicated than just matching the wiresanyone know where to find a wire diagram? Quote Share this post Link to post Share on other sites
Wervie67 0 Report post Posted October 26, 2009 if this is any help.... uses a stock external amp which most e30s do. take some pictures if your not sure diagram Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted October 26, 2009 e30 isn't colour coded. Pretty sure its the brown/purple wire that is the switched +!2V (acc) joins to red. You can figure out the wires with a multimeter which is the constant +12v, which is the switched +12v, etc. Quote Share this post Link to post Share on other sites
Wervie67 0 Report post Posted October 26, 2009 the two e30s ive worked on have been colour coded (both pfl if that makes a difference) but your right, multimeter's do save alot of time. and for speakers, just use a battery. Quote Share this post Link to post Share on other sites
