e30-redline
e30 huntint problem.
hey have just bought my 4th e30 a 1990 4 door 325i (was auto). just done a manual conversion but the engine is hunting rather bad on warm up idle but seems to run ok after a little while. check the idle control valve and all pipes and theres no air leaks.
any advise would be apprectiated cheers.
Had the same thing on mine. Cleaned AFM + AFM sensor, replaced intake boot, checked all other hoses for cracks + tightened hose clamps, cleaned ICV with carb cleaner.
It fixed it.
