MattA 165 Report post Posted January 9, 2005 Does any one know if the output flanges/shafts are interchangable with a non LSD. To explain what I mean I have a lsd diff head in london but it's missing the input and output flanges are these unique to the lsd or not? any info greatly appreciated an exploded diagram would be great if anyone has. cheers Matt Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted January 9, 2005 do ya mean the bits inside or outside the casing? if you mean outside, they look identical Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted January 9, 2005 not entirely sure but from the description "you can see gears inside" not sure if there should be a shaft/s visible or what. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted January 9, 2005 The stub axles that the inner CV's bolt on to (and go into the diff) are interchangable. However, there should be no gears (spider gears I presume) visible, just the crown wheel if it is still attached to the centre. Quote Share this post Link to post Share on other sites
