BMRBOI
18 Button On Board Computer OBC Upgrade?
Hi there in my e36 325i i have a 7 button on board computer, was looking through ebay and they have an 18 button conversion kit. i have a 18 button computer and the indicator stalk aswell, does anyone have the loom which they plug into? also how hard would it be to install it? worth the effort or nah?
http://cgi.ebay.com/ebaymotors/BMW-E36-18-...sQ5fAccessories
It's always worth it if you want to do it.
Having the wiring diagrams in front of me let's compare the two modules:
Old = Multi Function Clock, 6113.2 -> I'll call this CLK
New = On Board Display, 6214.0 -> I'll call this OBD
Power & Illumination connections
Pin 1 = BRAKE-TEST signal (connect to gnd when brake pressed) = only OBD
Pin 2 = BRAKE signal from brake pedal = same for CLK & OBD
Pin 3 = LAC lamp activation check (?) = same for CLK & OBD
Pin 4 = DATA = data signal = same for CLK & OBD
Pin 5 = CLK = clock signal = same for CLK & OBD
Pin 6 = CHECK licght connection = same for CLK & OBD
Pin 8 = Power in START = same for CLK & OBD
Pin 9 = Power in Run & Start from F23 = same for CLK & OBD
Pin 10 = Chime Module 1 = only CLK
Pin 11 = Chime Module 2 = only CLK
Pin 12 = Outside air temperature sensor = only CLK
Pin 13 = Speed signal from instrument cluster = only CLK
Pin 14 = Power in Acc, Run & Start = same for CLK & OBD
Pin 15 = Data signal from instrument cluster = only CLK
Pin 16 = Illumination from Light Switch = same for CLK & OBD
Pin 17 = Ground = same for CLK & OBD
Pin 18 = permanent power from F31 = same for CLK & OBD
So it looks like the Multi-Function Clock is the more complex of the two
The connectors are identical, so simply plug the new unit in
Then look at the wires and see what you are missing. My guess is:
1. Outside air temp sensor - so add the sensor and the one wire to make it work.
2. Brake Test signal - you may need a different brake switch for this
3. Data and speed from instrument cluster - add these wires
4. Chime - add these wires, and the chime module if not fitted
So the only things that won't work immediately are clock, chime, speed and data from instrument cluster
everything else will work.
Here is a full diy on doing it, has instructions for both 7 and 11 button units, I was going to do it myself but cannot find the 18 button and stalk at a reasonable price.
>>Click here <<
I'm pretty tempted to do this when I can afford it as well. I want the hidden functions! :D
What are the benefits of doing this?? lol what hidden functions?
