bimmerpig 0 Report post Posted November 19, 2009 (edited) Hi all. So summer is here which means its time to use the A/C again. First hot day comes and i switch on the A/C only to find that doing so makes water leak from the centre console behind the OBC into both the driver and passenger footwells. It's not alot of water but hey there souldn't be any water. If anyone has encountered somethin like this before or has a fair idea what the problem might be it would be much appreciated before i embark on some exploratory surgery. Thanks Harry Edited November 19, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 19, 2009 Hi all. So summer is here which means its time to use the A/C again. First hot day comes and i switch on the A/C only to find that doing so makes water leak from the centre console behind the OBC into both the driver and passenger footwells. It's not alot of water but hey there souldn't be any water. If anyone has encountered somethin like this before or has a fair idea what the problem might be it would be much appreciated before i embark on some exploratory surgery. Thanks Harry You don't say what model 320i? Check the A/C drain hose is connected properly & leading out through firewall Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 19, 2009 the heater box drain holes may be blocked !, they are supposed to drain through your trans tunnel. Quote Share this post Link to post Share on other sites
