318Touring 40 Report post Posted December 12, 2009 (edited) This is the one with plastic cap. How the heck can I remove it without BMW snap-on special tool? Any idea? TIA. Oil filter cap (top right of the picture) Edited December 13, 2009 by 318Touring Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted December 13, 2009 (edited) If its same as m52, isnt it like a 36mm socket? You can get them at repco for like $30 Edit: nvm, i see its alot bigger. Edited December 13, 2009 by turboprop Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted December 13, 2009 If nworst comes to worst get a peice of leather or something and wrap around it then clamp it with vice grips and undo it Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 13, 2009 or a oil filter removal tool should work Quote Share this post Link to post Share on other sites
318Touring 40 Report post Posted December 13, 2009 Really annoys me it's so hard, why couldn't they make it as simple as other cars. My generic oil removal tool is too big even at its lowest setting. Will check Repco tomorrow to see whether tehy have the removal tool... Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted December 13, 2009 If it's a socket, SuperCheap is cheaper than Repco. Having recently bought one for my VW. Quote Share this post Link to post Share on other sites
318Touring 40 Report post Posted December 13, 2009 I've actually managed to unscrew the top using a combination of leather belt and generic oil filter removal tool. Phew. Thanks everyone, I'll do the oil change later on today. Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted December 14, 2009 Get yourself an adjustable strap wrench - they are really useful to have in the tool box and pretty cheap. They are a handle with a piece of rubber belt attached (like a strip of cam belt without the teeth). The loose end threads back through the handle, pull the strap tight, grip the whole thing and turn. Once you own one you will find a new use for it every week. Quote Share this post Link to post Share on other sites
318Touring 40 Report post Posted December 14, 2009 turbolizard said: Get yourself an adjustable strap wrench - they are really useful to have in the tool box and pretty cheap. They are a handle with a piece of rubber belt attached (like a strip of cam belt without the teeth). The loose end threads back through the handle, pull the strap tight, grip the whole thing and turn. Once you own one you will find a new use for it every week. Good idea. I think this is the one, TM. Quote Share this post Link to post Share on other sites
