bekker
Torque setting
Hi guys,
Hoping some one can answer this soon as I'm about to get under the car and check.
What torque setting do you use for the Control (thrust) arm.
Haynes says 130 nm.
Anybody have a better recommendation?
Just do it untill its tight, doesnt really need to be done to a certain setting for this item, You just want it tight enough so it doesnt come loose.
Bentley agrees with Haynes, 130nm, done up under load.
Edited by Silver Fox
Cool thanks. Yip it's on ramps. Thanks heaps guys. BTW, is that the first time Bentley has agreed with Haynes? Edited by bekker
