savvi 0 Report post Posted December 23, 2009 hey guys found out my pick up pump in the tank has died, ive got a pfl 325i pump would this fit a 91 jap import e30 320i, cheers, shane Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 23, 2009 I don't think the facelifts use two pump setups like the PFL. The PFL uses one pump in the tank, a low pressure one.. and another near the engine somewhere for high pressure. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 23, 2009 hey guys found out my pick up pump in the tank has died, ive got a pfl 325i pump would this fit a 91 jap import e30 320i, cheers, shanewont work and to much hassle to make work i have correct one if your interested. kerry Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted December 23, 2009 I don't think the facelifts use two pump setups like the PFL. The PFL uses one pump in the tank, a low pressure one.. and another near the engine somewhere for high pressure. Not exactly, my PFL 323 and 325 had single pump systems with no intank pumps at all, my 88 FL 318 had twin pumps and I have had two 89's one had a twin pump set up and the other only had a single high pressure pump in the tank. Keep things simple and replace like with like. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted December 23, 2009 (edited) prefacelift has pump located left rear under the sill in front of the rear wheel, facelift has an intank pump, there are also diferent types twin hose or single hose give me a call if you have any questions also have fuel pumps Jon 0276 837251 edit; face lift pump is located under the rear seat on the drivers side, unscrew and lift black panel, undo 4 10mm nuts remove the sender first, then twist the whole unit counter clockwise and then carefully lift it out not to snag on the filter sock. Edited December 23, 2009 by Jono51 Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted December 23, 2009 (edited) prefacelift has pump located left rear under the sill in front of the rear wheel, facelift has an intank pump, there are also diferent types twin hose or single hose give me a call if you have any questions also have fuel pumps Jon 0276 837251 edit; face lift pump is located under the rear seat on the drivers side, unscrew and lift black panel, undo 4 10mm nuts remove the sender first, then twist the whole unit counter clockwise and then carefully lift it out not to snag on the filter sock. its got 2 pumps cos theres an external one in front of rear passenger wheel , thanks *pando: added end quote to fix Edited December 23, 2009 by pando Quote Share this post Link to post Share on other sites
