Andrew19863 0 Report post Posted December 28, 2009 I have a bit of a problem with my car, Last week my heater matrix cracked and steam and water leaked every where. Now the Problem i am having is that my speedo has stopped working... when im driving it flicks up and down but not properly going. Any suggestion what can be done to fix this. Help would be much appreciated. Cheers Andrew Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted December 29, 2009 (edited) You can buy a water dispersant for electronics (maybe d*ck smith) that will get rid of the water and prevent further corrosion. However given a week has already gone by I think it may be too late for that. I would pull the unit out and carefully pull it all apart and make sure everything is dry. Pay attention to the colored connectors and make sure they and the pins is completely dry. Also check the battery unit - its soldered to the board but just dry it the best yu can. If it still gives trouble after doing that replace the unit with a good used one it will be easier and cheaper in the long run. Edited December 29, 2009 by ducatiss Quote Share this post Link to post Share on other sites
