BlowMyWhistle
Spacers?
Hi Y'all, My springs turned up from usa today, there was a catalogue in it with spacers, up to 90 mm wide.
Does anybody ever tred running 8.5 (not 9.5 as previously reported) x18's on an e34?
I'd need about 70-80mm space, but will the wheels still turn inside the guards?
Any advice is appreciated, it's an expensive exercise buying spacers , fitting tyres etc...
At the moment I've got the rims advertised on ebay then I've got a set of 18x45's to pawn as well...
If it works I'll cancel the bid & fit them, any idea the dollars on spacers?
Cheers.
Cheers.
To answer my own question; e53 rims will fit with 28mm spacers up front & 22mm on back, so long as I'm only running 235's which I am.
style 58 offset 48mm e34 offset 15-26.
EH2 is the runflat tyre rims, but still good to go!
God helps those who help themselves, God help you if I find you helping yourself!
