1quad1 1 Report post Posted January 14, 2010 E30 M50 running 325i brakes I would like to put on something bigger Any Ideas ? Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted January 14, 2010 Looked at http://www.massivebrakes.com/home/ ? Quote Share this post Link to post Share on other sites
1quad1 1 Report post Posted January 14, 2010 Looked at http://www.massivebrakes.com/home/ ? A bit expensive !!! Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted January 14, 2010 Good fluid, Braided lines, quality discs and pads should be fine shouldn't it? JiB has upgraded his Brakes, read his build thread, hes using Nissan skyline Gts-T 4pot front calipers and E46 rear calipers i think, don't know what sort of/diameter discs Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 14, 2010 (edited) Be awaare that you start needing wheels with quite specific offset and caliper clearance (and unless you spend forever searching, 16" or 17" wheels as 15" becomes really hard). PM JiB and he might be able to enlighten you on exactly which front discs (300mm x 25mm with 40mm offset, originally 4x114). Its still not cheap by the time you've bought Nissan calipers, narrowed the fronts to suit the narrower discs and had custom mounting brackets made, then bought the discs and had them redrilled. Then also a master cylinder (23.8mm or 25.4mm) to suit. Edited January 14, 2010 by CamB Quote Share this post Link to post Share on other sites
djs325 0 Report post Posted January 15, 2010 The kits from Lee (Massive Brakes) are a good package given the price, which is reasonable given that everything is brand new, not second hand Nissan/Volvo/Mazda/Subaru calipers. That said, an E30 with an upsized master cylinder (25mm from an E32, available as a kit from BimmerWorld), good fluid, braided lines, rebuilt calipers, the right pads, and good rotors will stop very well indeed. Easier to put better wheels and tyres on the car to achieve better braking performance as well. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted January 15, 2010 as far as I'm aware there is no bolt on upgrade for E30's. Its either upgrade standard components, build your own kit consisting of various manufacturers components modified to fit (eg audio tt rotors and 5 series calipers) or do it properly and get a wilwood/brembo etc kit. again either from a package like massive or something you put together yourself. Quote Share this post Link to post Share on other sites
