nastnas
brake problems
hi guys,
about 2 weeks ago, i changed my discs and pads, when this was done i did not bleed the system, just pushed the pedal back. as i was took the car for a test drive i noticed the pedal was really spongy on the first press of the brakes. ( the 2nd press requires less brake pedal travel)
at the time i thought it was just the new discs and pads, so they need to bed in... well today the problem was still going on, so i figured somehow i should bleed the system, so i put in dot5.1 fluid... but the pedal is still spongy.... Posted Image
any advice, much appreciated.
You might have damaged a seal in the master cylinder...
I have a habit of doing then when i bleed my brakes...
did u bleed the system properly?? you need 2 guys to bleed it. 1 pumping the pedal while you are at the bleed valve letting out air. on all 4 brake calipers.
i was at work today, and dropped the car off at the garage around the corner to get the sytem flushed with dot 5.1. im assuming they have got it right.
