E30-323ti
E30 & 5 Lug bits FS
Hi Guys.
I have some bits forsale:
Complete E30/36 5lug rear assembly.
This includes urethane trailing arm & subframe bushes (1mth old) and hand brake cables if req'd.
Comes with a Medium case diff (3.46, 3.64 or 3.91 your choice) & axles.
It is all fully assembled all you need to do is bolt it in (3 bolts) and connect the brake hoses & cables.
$1100ono
(FYI If you ring around you'd be lucky to get the trailing arms only for that!!)
A must have if you are a track junkie that needs bigger brakes (in combination with fronts of course).
Posted Image
New E30 Rear Koni shocks.
These were special order SP1 models not the normal "Sports".
They have different rebound valving than the sports (so I've been told) to suit road and track use.
These were used for 1mth also.
$300ono (or $400 with springs below)
New E30 Rear King Springs (Super Low)
Don't be put off by the "super low" as they aren't that low.
The rear ride height on my E30 was 330mm (from the wheel centre to the arch) nb. pre-FL arches.
1mth old also
$150ono
Posted Image
New E36 Rear Koni Springs (40mm drop)
These came with my coilover kit, never been used.
Don't know what rate they are but they look beefy.
$200ono
Posted Image
Parts for sale soon:
5spd Conversion kit for a M20 (E30)
It is from a '86 320i that has done ~150k
Will come with pedal box, clutch lines, shifter assembly, driveshaft, flywheel & clutch, everything you need.
It is still in the car but will pull out if needed asap.
$600ono
Thats all I can think of for now so drop me a PM if you are keen on anything.
And if you are wondering why I'm pulling out a 1mth old rear end, it's 'cause I can't find a f*#king LSD so I have to move on and DIY it (E28 backend with a supra LSD) what a PITA!!!
shotgun on the rear konis....just gotta see if i actually need em..
Guest Spargo
Its an E36/5 setup G?
What shocks and springs are used?
Its got compact brakes at the mo'?
OT: what do E36 M3 brakes retail for these days?
Hi Sam,
Yes they are the compact arms, so all the brake line fit the E30 (E36 7/8's don't).
The E30 shocks & springs for sale above.
Rear brakes are 272x10.
[OT]
Front E36 M3 discs are ~$240ea, but you need a M3 hub & caliper (if you can find a pair)!!
Much better off using E46 330i front brakes they are 325x25 @ $125ea and the calipers bolt onto any E36 hub (except M3's) and they use the same pads as an M3 (calipers are hard to find, maybe OZ?).
Failing that E46 328i discs are 300x22 and also bolt on, normal E36's are 286x22 (still alot better than the 260x22 of the E30), Complete E36 front hubs are ~$150ea from a wrecker (cheapest part of the 5lug swap).
[/OT]
