tire
I need options
I want to fit the later style shifter to my early G240. Is there a way to accommodate it? The bracket its meant to sit between at the gearbox end is non existent.
Other option is to run with the old shifter that came with the manual conversion kit, its the big metal plate style thing. But the plastic shift cup it came with doesn't even fit :wacko:
If I can't get a solution tonight I'l take mattzys 260 which this late shifter cam out of and put that in. But I'm unexcited by the thought of this.
Ideas?
1st pic is plastic cup not fitting
2nd is old style shifter
3rd shows where the bracket to hold the late style shifter is meant to be
4th shows the end of the late shifter thats meant to go into said bracket
Edited by tastic
