Matty104
WTB: Rising rate fuel pressure regulator adaptor
Hey guys
Im looking to buy a Rising rate fuel pressure regulator, for the m20
But what i need is an adaptor that will allow me to tap into the fuel rail in the same way that the factory fpr does with the push it o-ring type fitting
Like THIS But with an m20 fitting
I can find kits for m50's but none for m20s
So if anyone has purchased one or knows where i can source one let me know. (would ultimatly prefer in NZ)
Cheers
  Matty104 said:
Hey guys
Cheers
I just used an old FPR, drilled it and attached it to the adjustable regulator
What do you mean by drilled it? ,
I cut the top off one then gutted it and welded a cap on , (but it had a small leak so i thought id ask if there is proper one forsale.
get the welder back out haha , got that resistor ready for you man
