37 South
Transmission
my transmission suddenly died while stopped at traffic lights. Dropped from D into neutral and would go only by shifting into N. Managed to get home,gears shifting o.k. while in `N` position.After parking in drive way,I could not get into reverse or any other position.Had it towed to Eastern Automatics in Newton and they told me it probably a clutch band welded and they gave me the impreesion it would be quite a job (5-7 working days to repair)So what am I going to do? Can`t really afford a lot of money to spend on it.
Any advice what I should do?Get it fixed or is it not worth it?
Might be worth talking to Ray (HellBM) or Brent (Hartge535 or something similar) - they may be able to do a replacement trans or even a manual conversion for reasonable $$$.  Just depends how much you want to spend, and how much the other guys are after for the repair....
