37 South 6 Report post Posted June 1, 2010 my transmission suddenly died while stopped at traffic lights. Dropped from D into neutral and would go only by shifting into N. Managed to get home,gears shifting o.k. while in `N` position.After parking in drive way,I could not get into reverse or any other position.Had it towed to Eastern Automatics in Newton and they told me it probably a clutch band welded and they gave me the impreesion it would be quite a job (5-7 working days to repair)So what am I going to do? Can`t really afford a lot of money to spend on it. Any advice what I should do?Get it fixed or is it not worth it? Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted June 1, 2010 Might be worth talking to Ray (HellBM) or Brent (Hartge535 or something similar) - they may be able to do a replacement trans or even a manual conversion for reasonable $$$. Â Just depends how much you want to spend, and how much the other guys are after for the repair.... Quote Share this post Link to post Share on other sites
