mercenary
E30 Rear Drums to Discs
Hi, Im changing the rear brakes on the series car im building from drums to discs and wondering if anyone can confirm if i need to change the master cylinder or not?? im sweet with the other parts just would appreicate confirmation on this point.
cheers
Andrew
Existing master is fine, I did the same change on my first race car.
Awesome. Thanks Silver Fox.
Master cylinders are the same - as Dave eludes to
There is a biasing valve fitted to the rear line though in cars with a rear disc setup
