Fabo 0 Report post Posted June 24, 2010 Hello to all, just wanting to know if the "Zimmermhann Cross-Drilled And Slotted Rotors" were worth the price $400 (FRONT PAIR) and the "Zneolli Slotted Rotors" worth $350 (REAR PAIR) are a worthwhile upgrade? Also along with this which brake pads bite quite well I'm having trouble finding any? And what 4pot calipers fit the e30 as I would like to upgrade the brakes early in the project. Thanks Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 24, 2010 imo no.. what are you trying to achieve? do you have some kind of performance project lined up? if so where are you wanting to take this car performance wise? if your staying with the e30 brakes then brembo rotors and some ebc or mintex pads will be pleanty. if your going big hp and need biig brakes you can get brembo, ap etc etc kits but they are not cheap from what i gather. Quote Share this post Link to post Share on other sites
Fabo 0 Report post Posted June 25, 2010 imo no.. what are you trying to achieve? do you have some kind of performance project lined up? if so where are you wanting to take this car performance wise? if your staying with the e30 brakes then brembo rotors and some ebc or mintex pads will be pleanty. if your going big hp and need biig brakes you can get brembo, ap etc etc kits but they are not cheap from what i gather. For the mean time just an uprated m20b23 then later a turbo conversion and if I can find a 2.7 block a 2.7 turbo The first option sounds good where do I buy the mintex pads? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 25, 2010 just about anywhere. repco, supercheap, brake and trans. places like that should be able to source them Quote Share this post Link to post Share on other sites
Fabo 0 Report post Posted June 25, 2010 just about anywhere. repco, supercheap, brake and trans. places like that should be able to source them Sweet as Thanks alot Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted June 26, 2010 Ring Mal at bygone auto's for the mintex pads. Quote Share this post Link to post Share on other sites
