kiwi535 538 Report post Posted June 26, 2010 was leaving the supermarket and pressed the windscreen demist button,this puts the fan onto full speed and directs ALL air onto windscreen,the fan blew full speed for a couple of seconds then seemed to stop.only seem to have low speed on the fan now ,cannot increase speed. Is this the "sword" or is there a seperate fuse for the record the IHKA is the 'automatic' system,continuously variable fan speed Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted June 26, 2010 (edited) was leaving the supermarket and pressed the windscreen demist button,this puts the fan onto full speed and directs ALL air onto windscreen,the fan blew full speed for a couple of seconds then seemed to stop.only seem to have low speed on the fan now ,cannot increase speed. Is this the "sword" or is there a seperate fuse for the record the IHKA is the 'automatic' system,continuously variable fan speed hey Paul, bugger wrong time of year for this to happen, check fuses, then start looking at the resistor, then ihka module currently wrecking a few E34's give me a yell Jon Edited June 26, 2010 by Jono51 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 26, 2010 hey Paul, bugger wrong time of year for this to happen, check fuses, then start looking at the resistor currently wrecking a few E34's give me a yell Jon thanks Jono may well do that in the meantime the real use for a/c in welly will have to come to the rescue,have you got a e34 withthe ihka system?(horizontal thumbwheels for fan and temp) Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted June 26, 2010 should do, but will double check, just got another E34 in give me a call on monday cheers Jon 04 3801089 Quote Share this post Link to post Share on other sites
