rusteee
Rattle from engine bay (Not Vanos rattle)
I have a 97 E36 320i, I started it up when cold and there is a hell of a rattle in the engine bay somewhere, but only seems to be when the heater is on? It sounds like the air-con, as it clicks on and off (and sounds like its in the vicinity of the alternator belt etc), but in saying that I never had the air-con on. Does the air-con compressor still run when you have the heater on? It also seems to get quieter as the car warmed up but still rattles.
Also, I hit a goddam possum, and I wasn't exactly going slow. Suprsingly the damage wasn't too bad :rolleyes: but it smashed the fog light out of the passengers side of the front bumper, and also I noticed there is something hanging down, looks like a rod (temperature sensor) of some sort, with 2 wires plugged into it. I don't wanna fiddle or try to find where it came from unless I know what it is, any ideas??
Cheers guys
Edited by rusteee
Sounds like the sensor might be the external temperature sensor. I think they normally sit behind the passenger side fog lamp or headlamp. Someone else will be able to confirm.
As for the noise, it could quite well be the A/C compressor. While the compressor may not be engaged the pulley at the front still spins when the engine is running - it is belt driven. Best get it checked - if it sounds that bad it could seize and bust the drive belt.
Oh thats good, I was hoping it was something like that.
Yea I want to take it in and get it checked before it does gets worse, but seen as I live in the middle of nowhere, its hard to get the car to a specialist on a weekday lol. It does sound like the belt, or aircon, it's something that cuts in and out all the time anyways.
Cheers for the help!! Much appreciated
The temp sensor usually plugs into the side of the brake duct. I've left mine wrapped around some other wires, my brake duct doesn't exist anymore :P
