Gunner 0 Report post Posted July 5, 2010 Hi, Just noticed that after i close my doors the window isn't sitting flush against the weatherstrip anymore. Checked the weatherstrip, took it off and put it back on and it appears that its fitted correctly but there is still a little gap which is clearly visible from the outside. Has anyone else come across this problem before? Quote Share this post Link to post Share on other sites
kelly00527 0 Report post Posted July 12, 2010 Hi, Just noticed that after i close my doors the window isn't sitting flush against the weatherstrip anymore. Checked the weatherstrip, took it off and put it back on and it appears that its fitted correctly but there is still a little gap which is clearly visible from the outside. Has anyone else come across this problem before? every time you close the window, just use your hand to adjust the windows as it goes up.......lol just for now until you can figer out whats going on. Quote Share this post Link to post Share on other sites
