_Matt_
Replacing Indicator - What's This for?
Hi there. Poorguy was nice enough to send me an indicator from his 528i as the plastic broke in mine so it couldn't return.
I thought it would be a relatively simple swap but have come across this...
This is a connection from my old indicator:
The input it went into: (from the column)
The new indicators output.
so, not quite sure what to do here. Can anyone shed some light on this? BTW - i have tested the new indicator and everything works so i am even more intrigued on what this grey wire is for :)
Cheers.
just chop and join your old connector into both those white wires.
they both go to the same place as you can see they join in the 1 pin plug.
i think im on the right track??? your post was kinda confusing.
or is your indicator already hooked up and working and that wires just a left over? if so i would just leave it. may be for something that does not come in your car. ie alarm or something.
Edited by DRTE30
that's what i was going to do...was just wondering why the extra wire was needed :/
Edit: the original wire leads into what i think is the back of the ignition. and yes, all works ok without it, it seems.
Edited by _Matt_
