Surge
Removing Exterior 'Bump Strips'
As per the title, how does one go about removing the door/trolley stopping plastic strips that run around the door and the latter part of the fender and rear panel.
I can find one screw thats visible from the exterior (inside the door down from the locking mechanism)
Have an Mtech2 replica kit that I want to get put on which requires the removal of the above part.
Cheers,
James
unscrew that plastic nut.....then they just pop off....its not hard you should figure it out
Excellent, thought that would be the case with the door and rear ones. The very front bit, does that require the removal of the piece which covers the speaker near the glovebox?
well you could go that way..but you may have to cut through some nifty 2/3 layer steel structurial framing
or you can just pop it off with a screw driver...
if it dont just pop off undo the mudflap and the plastic innerguard there and have a look see
the choice is yours
