Surge 1 Report post Posted March 21, 2005 As per the title, how does one go about removing the door/trolley stopping plastic strips that run around the door and the latter part of the fender and rear panel. I can find one screw thats visible from the exterior (inside the door down from the locking mechanism) Have an Mtech2 replica kit that I want to get put on which requires the removal of the above part. Cheers, James Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted March 21, 2005 Take the door card off and all will become clear. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted March 21, 2005 unscrew that plastic nut.....then they just pop off....its not hard you should figure it out Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted March 21, 2005 Excellent, thought that would be the case with the door and rear ones. The very front bit, does that require the removal of the piece which covers the speaker near the glovebox? Quote Share this post Link to post Share on other sites
Homy.D.Clown 0 Report post Posted March 21, 2005 well you could go that way..but you may have to cut through some nifty 2/3 layer steel structurial framing or you can just pop it off with a screw driver... if it dont just pop off undo the mudflap and the plastic innerguard there and have a look see the choice is yours Quote Share this post Link to post Share on other sites
